When using a Holley carb with a 700r4 trans will it damage the TV cable or trans?
Old Mar 24, 2002 | 03:36 PM
86Tra/maro's Avatar
From: Newark,NJ The state where racing on I 78 rules.
When using a holley carb with a 700r4 trans do I need to buy any special adapters for the kickdown cable. On the Holley box, it's saying something about damaging the700r4 trans If some type of bracket is not used.
njdaewoo
Old Mar 24, 2002 | 03:52 PM
Cosmik Debris's Avatar
Re: When using a Holley carb with a 700r4 trans will it damage the TV cable or trans?
njdaewoo
The warning on the box is Holley's way of protecting themselves against liability. You can make th TV cable work with the standard bracket with a bit of bending and repositioning but the Holley bracket (part no. 20-95) is pretty cheap.
Old Mar 25, 2002 | 08:35 AM
86Tra/maro's Avatar
I thought it had more to do with the geometry of the mounting point. The Q jet looks like the attachment point is closer to pivot point on the shaft of the carb. Does the part U mention move the mounting point higher on the carb's linkage?
Old Mar 25, 2002 | 03:34 PM
I can't remember where the cable was positioned on the Qjet it was too long ago. The holley bracket goes under the rear carb bolt and accommodates the throttle and TV cables.
Old Mar 25, 2002 | 04:00 PM
Ls1smlblck1's Avatar
ditto: the only thing u would worry about adjusting the TV cable right. The best way is to get at least a 300 psi pressure gauge and plug into your pressure tap. try 700r4.com, they can go into further detail about adjusting with the gauge+ they sell it too if you need one.:lala:
Old Mar 25, 2002 | 07:07 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes, what LS1 said.
I found a trick way to aid in the process of adjusting the bracket to make the adjustment easy for holley/edelbrock. Take a spare cable bracket assembly (stock one) and cut the tv cable holder off at the bend. You should have a piece with the clip hole and a bolt hole left. Since your using a holley you probably have an after market manifold with a threaded hole right at the bottem of the rear fuel bowl, 3 in back from the ac bracket on the manifold same height. Turn the cut off tv bracket around and attach it to this hole, then pop the cable in there. Now turn the tv screw on the carb linkage around so the ball/clip part faces the carb. Attach the tv clip and adjust. GTG.
I should have a pic or two in a week.
Old Mar 26, 2002 | 08:30 AM
86Tra/maro's Avatar
thanx!
Frozer!!!
Jan 19, 2024 04:55 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
