9-bolt Gears vs Jegs.
Old Mar 24, 2002 | 10:38 PM
JEFF'S GTA's Avatar
Car: '89 Trans Am GTA
Engine: 350 5.7L.
Transmission: 700R-4
Axle/Gears: 9-bolt with 3.73
I was told that the 9-bolt rear end was a 7.625in. I may be wrong let me know if I am. I was looking in jegs and I saw a 10-bolt that said it was a 7.5 and a 7.625. Now is a 10-bolt 7.625 and a 9-bolt 7.625 the same thing? Would the gears work from a 10-bolt 7.625 fit in a 9-bolt 7.625?
Old Mar 25, 2002 | 01:01 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
A 9-bolt ring gear is 7.75". No, a 10-bolt and 9-bolt gears are not the same and will not fit with each other.
Old Mar 25, 2002 | 01:16 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Just like Kevin said above. The 9 bolt is a 7.75 ring gear. None of the internal parts of a 9 bolt are interchangable with a 10 bolt.
Miles
www.9bolt.com
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
amcnellis
Sep 16, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
