My rear differential is making noise??...
Old Apr 7, 2002 | 03:51 PM
ChevyLuva3's Avatar
Hey all, I've noticed this sound before but never knew where it was coming from. Its when I make a turn like 90 degree turn, I hear a "whirring", first I thought it was the power steering pump, they're loud, and kind of "whine". But today, I had my music down, and turning slow in the parking lot, and I could hear this whirrrr whirrrr whirrrrrrrr noise. It happens EVERY time I turn. It sounds like its coming from behind me.. my differential? gears? posi? I went around in a circle in a parking lot, and it kept making the noise. The sound is like a combination of "whirrrrr", a zipper zipping up, and bubbling water, if that helps . What is this noise? Whys it there?? Any help would be appreciated.
..Oh BTW, today I was going down a hill, and missed my turn, and since no one was around, I decided to stop, and reverse back up the hill into a driveway to turn around... but for some reason I pushed the gas, and there was mutliple THUMPS coming from the rear. Did I hit the gas too early, that the gear didn't engage just yet? What happened there??
Old Apr 7, 2002 | 05:44 PM
Jay 727's Avatar
Sounds like posi needs a fluid change, use genuine GM posi additive.
Old Apr 8, 2002 | 03:13 PM
ChevyLuva3's Avatar
Back to the where?
TOP
Old Apr 9, 2002 | 03:56 PM
ChevyLuva3's Avatar
Aight thanks Jay, I'll change fluid, any more suggestions? How bout that multiple thumping when I hit the gas in reverse?? Any help is appreciated.
Old Apr 9, 2002 | 10:12 PM
IROC315's Avatar
Car: 01 Z28 and 89 Iroc
Engine: ls1 fti 3600,S60 w/3:73 gears
Transmission: A4
Axle/Gears: 3:23
It could be the u-joint going bad.
I would take the cover off and inspect the ring gear also. Missing teeth can cause that too.
Old Apr 9, 2002 | 11:42 PM
ChevyLuva3's Avatar
Is that the problem, from the fact it makes noise, or the fact it thumped? Or both?
I was thinking maybe I didn't let the car fully shift into reverse, or maybe I was rolling down the hill, and the gear didn't mesh or something. See the thing is, if I slowly push on the gas in reverse, its just fine. But sometimes if I hit it hard, it has like hesitating tendency and kinda thumps, weird.
BTW, if it is bad ring gears and stuff, that mean I can get new gears? Cool, now my car can move quicker... however I have a 9 bolt . Where would I ever find them??
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Sep 17, 2020 08:26 AM
B_Dubya
Aug 26, 2015 05:09 PM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
BlackBoulder
Aug 11, 2015 11:15 PM
