"Cones" in the rear end????
Old Apr 13, 2002 | 04:55 PM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm currently speaking with a guy about buying a carrier and 3.27 gears for a BW 9 bolt rear end and he mentioned something about "cones" in the rear end. He said that they needed to be replaced. Do these "cones" have something to do with the posi and if so, can they be replaced without buying a new carrier. Also, if they can be replaced, how much are these "cones" and how hard are they to replace? TIV
Old Apr 13, 2002 | 05:17 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i just installed a cone style posi in my 10 bolt. the cones are part of the posi. they are fitted to the carrior, causing them to grab when you spin the tires. it is a hard thing to describe. maybe someone else can help me out to give you a better idea.
Old Apr 13, 2002 | 05:25 PM
Jay 727's Avatar
While clutch type posis are rebuildable cone type posi's are not. The cone rides on the inside of the carrier so it's usually worn out too. I don't know of any source to buy new cones.
Old Apr 13, 2002 | 05:27 PM
Ok, so if the cones are shot then the posi is shot and I need to just buy a new carrier. Or can the posi part be replaced somehow? I know just about nothing when it comes to the workings of the rear end. I just know gear sizes and the difference between posi and not.
Scratch the above.... I saw the answer after I asked the question.
Thanks guys.
Old Apr 13, 2002 | 11:42 PM
Jay 727's Avatar
If the cones are shot that means the carrier is shot, you need a whole new posi unit.
Old Apr 14, 2002 | 09:23 PM
Eightyninef's Avatar
you can machine the cones down and shim it tight again. cheaper than buying a new posi.
Larry Burd
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
