flexplate style
Old May 26, 2002 | 04:44 AM
bernd5179's Avatar
flexplate style
Does anyone know if the flexplate style of a 60° 2.8 V6 is the same as the ones used on V8s? Cause in the GM performance parts cataloge they state that 90° V6 are interchangeable with the V8 but they don t mention anything about the 2.8.
Old May 26, 2002 | 05:34 AM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
no it is not interchangeable
the 90* V8 is a much larger engine
our 60* V6s are actually quite small
plus the bolt pattern is different
as for the 90* V6, it is basically a 90* V8 with two cylinders knocked off
hope this helps
Old May 26, 2002 | 09:46 AM
bernd5179's Avatar
it helps thanks
Old May 26, 2002 | 10:02 AM
OnixV6's Avatar
FYI, you're referring to the 90* 4.3L V6. the 90* 3.8L Series 2 V6 in the later model 4th gen F-body is not a 90* V8 with two cylinders knocked off.
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bschmale66853
Sep 30, 2015 08:11 PM
