Attn: MDV6MAN
Old Jul 2, 2002 | 07:13 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Attn: MDV6MAN
I seen on a profile that you have fiero valve covers on your 2.8l camaro, Can you post a pic of what they look like on their. Also, did everything line up, did you have to extend any hoses?? Thanks
Old Jul 2, 2002 | 10:30 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Sorry dude, I don't have a digital camera to post any pics of the finished product. I can tell you what's involved/needs work in order to make it successful. When you go to the Junkyard to pull them, take the bolts with you . Also the fiero uses a special gasket for the valve covers. Pep boys sells a pair for about 20 bucks. The front bolt on the drivers side may be needed to be bought at the parts store as well. this is so you can mount the vacuum line bracket in the same location. If you choose not to reuse the bracket, just use the stok fiero bolts. The top and bottom plenum and the injectors need to be removed to get to all of the bolts/and remove the valve covers. Do not use any gasket sealer as the gaskets are of a special material and are to be installed dry. Everything lines up and just use your original grommet on the passenger side valve cover
Old Jul 2, 2002 | 11:17 AM
Dale's Avatar
Engine: 350 S-TPI
Thanks for the info. Think I might be going to parts yard this weekend looking for a headliner, so I will look at them as well.
Old Jul 2, 2002 | 11:34 AM
Dale's Avatar
Engine: 350 S-TPI
OO yea, plus, i gotta change valve cover gaskets anyway, so why not mod it
NEEDAZ
Car Audio
Jun 23, 2005 07:15 AM
ES87iroc
Mid-Atlantic Region
76
Oct 17, 2004 08:40 PM
ES87iroc
Mid-Atlantic Region
38
Sep 25, 2004 09:15 AM
ES87iroc
Mid-Atlantic Region
82
May 12, 2004 01:33 PM
90TA
Jan 20, 2003 09:05 PM
