power part numbers
Old Jul 10, 2002 | 02:27 AM
RPS's Avatar
RPS
power part numbers
what are the part numbers for Crane's 3.1 1.6:1 rollerrockers? and price.
who makes a true doubble roller timing chain, and whats the part numbers. how much?
which valve springs would go good with a Crane 2030 cam #CRN-254122 duration:264in/274ex lift:.423in/.423ex 1,500-4,500
i want to eventualy build the engine with forged pistons after bore .30 over, forged valves, forged rods
have any of you completed a rebuild with forged internals?
Old Jul 10, 2002 | 10:00 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Re: power part numbers
I don't have numbers for crane, just comp cams... you can find the part #s thru their online catalog. In fact you can find the part # for the "rocker and pushrod" kit, too... check prices at summit racing.
Cloyes, I bought mine from Summit Racing for $90 three years ago. You'd have to call and ask for a part #.
[b]which valve springs would go good with a Crane 2030 cam #CRN-254122 duration:264in/274ex lift:.423in/.423ex 1,500-4,500[b]
You might want to give http://www.cranecams.com an email or a phone call to see what they recommend for their cam. Chances are that they'd know the best!
Old Jul 10, 2002 | 12:50 PM
RPS's Avatar
RPS
thanks man!
Old Jul 10, 2002 | 10:52 PM
RPS's Avatar
RPS
do the elbrock 2.8 valve covers clear the 1.6 roller rockers? can i still use the stock ones?
will using 2 gaskets per cover give me proper clearance?
i have the part numbers for the Chevy V6 60° Roller Rockers 1.6
$135.99 #CCA-1414-12
www.summitracing.com
Old Jul 13, 2002 | 04:20 PM
RPS's Avatar
RPS
after digging up the numbers here they are...
seems jegs has a much better part search than summitracing.
these are jegs numbers
Crane Cams High Performance Valve Springs & Retainer Kits - Valve Springs
Item # 270-99848-12 $ 64.99 $ 64.99
Cloyes True Roller Timing Chain - Chrvy V6 2.8L, 1980-91
Item # 220-9-3137 $ 92.99 $ 92.99
Catalog Item - 2.8 V6 ROCKERS 1.6
Item # 249-1414-12 $ 135.99 $ 135.99
1992 Trans Am
May 10, 2023 07:19 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
355sbcTPI
Aug 19, 2015 04:38 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
