how do you remove.....
Old Jul 26, 2002 | 08:55 PM
Bluerocket's Avatar
How do you remove the fuel rail asmembly?
Old Jul 26, 2002 | 09:35 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
pry that sucker off. Lube the o-rings around the injectors, your're going to replace those anyhow. right
Old Jul 26, 2002 | 11:22 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Two 10 mm bolts on the back right side of the car, then 3 torx bit screws that hold the fule lines on. (dont forget to relive pressure first, and will still spray a bit) then grab n wiggle a while. This is all assuming the upper plenium is already off, which is a few 10mm and 13mm bolts.
Old Jul 27, 2002 | 07:59 AM
Bluerocket's Avatar
Thanks the engine is not in the car any more and I had the plenium off already
