scanning the 1227302
Old Aug 6, 2002 | 01:45 AM
funstick's Avatar
hey guys ive been scannign the 1227302 with the winaldl software and the simple one transitor interface. im using the 1985 mpfi setting in winaldl. its for a 1227170 ecm but the data appears to be correct when refernced to a gm tech 2 hope this helps you out.
Old Aug 6, 2002 | 09:12 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Thanks for the info, funstick!! I've gotta build that little cable one of these days...
Old Aug 6, 2002 | 03:14 PM
LinuxGuy's Avatar
Car: 1992 Camaro RS
Engine: 5.0L TBI
I've been using WinALDL over the last few weeks too, and I must say, it's been handy. It's also just kind of neat to see the data going by and what the ECM is up to. Came in handy for adjusting my TPS.
I've got a 1989 Camaro RS with the 1227302 ECM and the 1985 2.8 MPFI setting does seem to report more accurate results on a few sensors (BAT voltage, Rich/Lean counter if I remember right), can't remember for sure though. The 1986 2.8 MPFI setting shows spark advance though...
Also, on a side note, I put a Holley Ignition Control Module, MSD Blaster GM, and MSD Superconductor wires on my '89 RS this last weekend. Also replaced the TPS (could not adjust previous one below 3.2v at zero throttle!). The car idles and starts SOOO much better now. It idles smooth, starts great, and I THINK there may be just a LITTLE extra ooomph (may be in my head too). Up next, Dynomax!
-Jason
_________________________________________________
1989 Camaro RS, 2.8L V6, 5 speed, T-Tops, 87,000 miles
1987 Camaro SC, 2.8L V6, 5 speed, T-Tops, 128,000 miles
1992Z28!
Nov 19, 2015 07:33 AM
RGB2015
Sep 20, 2015 09:26 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
Corry
May 31, 2001 08:52 PM
Mark305TBI
Jan 28, 2001 11:20 PM
