MSD 6AL + GM coil, do i need a harness?
Old Sep 2, 2002 | 10:47 PM
OUTATIME GTA's Avatar
Car: '89 GTA
Axle/Gears: 3.27/9-bolt
just ordered the MSD 6AL and the MSD GM coil, do i need a harness to plug and play or do they both go right in? thanks!
Old Sep 3, 2002 | 07:19 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I forget the part number, but MSD makes a wiring harness that makes installation of the 6AL a breeze. It's not expensive, and worth every penny. Best of all, if you decide to take the 6AL out, you can easily return the car to stock set up.
Check MSD's web site or call Summit Racing for the part number.
Old Sep 3, 2002 | 08:29 PM
Car: '89 GTA
yah i saw that harness, so it isn't a must, but it makes it easier to in/uninstall?
it's the one for like $30, right?
Old Sep 4, 2002 | 09:16 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, it's not a must, but it's easier. I chose to buy it for the same reason that Mike just mentioned- it allows me to plug my original coil in in case I die on the side of the road, and think it's my ignition box. My GM coil is still in it's original place, I've wired up a Blaster SS coil... so if you're replacing your GM coil, you really don't have a stock ignition to go back to.
Old Sep 4, 2002 | 12:09 PM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
When I installed my GM Blaster coil, I didn't have much choice but to remove the stock since it was dead. I would definately splurge and get the harness, makes the install so much easier.
Hey I think this is my first time posting with the new sig. You guys like it?
Hotrodboba400
Dec 10, 2019 07:07 PM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Jlanz55
Sep 6, 2015 03:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
