V6 performance parts
Old Sep 24, 2002 | 09:32 PM
N/A89CamaroRS's Avatar
Car: 89 Camaro RS
Engine: LO3
Transmission: 700-R4
Where is a good place to get V6 performance parts? I'm looking for heads, headers, exhaust, cams, ingition, all of the goodies, but for a 3.1L. I wanna make this baby roar as loud as possible. I was thinking of going to a 5.0L 305 or a 350, but I can't find em used for a Camaro. Help!
Old Sep 25, 2002 | 08:49 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Summit Racing has parts for the 60* v6. The parts are not listed in their catalog but if you call them they can send you in the right direction. There are no aftermarket heads for our v-6s. The best bet would be to get a set of heads from a 93-95 3.4L camaro and put them on. Headers are no longer mass produced but there is a guy on the board (Camaro Hunter C) who makes them. An exhaust shop will have to make a custom Y-pipe. The two most popular Cam manufacturers are Crane and Crower. Check some of the other threads in this forum for more ideas.
Old Sep 25, 2002 | 09:30 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Summit and jegs will be your best bet. Like 91rs said, headers are no longer mass produced for direct fit into these cars, and the heads, If i rem the post correctly, the only diff was bigger springs, the openings and such were the same. Cam, rockers, 3.4 stroker kit/swap, muffler, home made cai, ignition, no overside TB Just to name a few.
Dale's Avatar
Engine: 350 S-TPI
oops, i ment mdv6man
Old Sep 25, 2002 | 11:48 AM
Car: 89 Camaro RS
Engine: LO3
Just to be an off-the-wall dumbass, what is the likliness that a 3.8L V6 from a 4th Gen Camaro will fit into my car? I like those engines and their power and the aftermarket for those V6's is incredible. What do oyu think?
Old Sep 25, 2002 | 11:56 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Unlikely... you'd also have to change the whole computer. The 3.8 is too wide to fit between our strut towers. For the '89 turbo trans am, which used a 3.8, GM used smaller heads- from I believe, a front wheel drive 3.3 car - to get the 3.8 to fit. And like I said, you'd have to change the whole computer and wiring harness out. And if you have an automatic transmission, you'd have to change it, because the 2.8/3.1 trans won't fit up to a 90 degree 3.8 V6. If you have a manual trans, you might be able to redrill the bellhousing, but even then, I don't know what you'd do for a clutch setup.
It'd be a cool project, but just like the "I want to twin turbo my 2.8" idea, everyone just talks about it, and never does it.
Old Sep 25, 2002 | 04:05 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
get heads off a FWD 3.8
for the tranny if you have an auto you will need to get a V8 tranny and a chevy to BOP bolt pattern adapter plate
for a manual just simply use a 95-02 3.8/ T5 bellhousing
now that i think about it, i believe the stock heads will fit, i think you need the FWD if you want to retain your A/C........
LT1Formula
20
Nov 14, 2015 12:02 AM
86IROC112
Aug 17, 2015 02:00 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
