Fuel Smell
Fuel Smell
Smell is coming from the drivers side rear tire well. I know the fuel filter is right back there and I just replaced it about 2 months ago. I spot NO leaks of any kind. Why am I getting this smell???
Our tanks like to crack right at the base of the filler neck. It will leak fumes only...unless the tank is overfilled.
There is a recall for it...but only for 91-92 cars. It sucks because I have a '90 and mine is cracked.
Hmmm, cracked filler neck? Is this hard to get to? Maybe I could put some sealer on there or something.
How does, and how would you eliminate overpressure in your gas tank?
Thanks!
Thanks!
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Thanks!
Thanks!
If so your looking at money and some time. I changed mine in my parents driveway at home. So it can be done, but its very tedious.
Car: Firebird
Engine: 3.1 L
Transmission: auto
maybe it's only the lid that is not tightly. But if you don't see any gas droping or leaking and you gas/milage is like before, and you don't smell it all the time,I suggest don't worry (pierda usted cuidado)
Horst
Horst
Check your charcoal/air canister, located under the hood, passengerside, in front of fender liner (thats where mine is, not sure about V6). Filter on bottom of canister will plug and cause fumes to back up from the fuel tank. Auto Zone sells the filter for around a buck. Had it happen to mine, GM manual said to check it and that was it.....
