Couple Simple Questions...
Old Oct 10, 2002 | 11:05 PM
JadesAn89's Avatar
Okay - call me lazy, but what size are our guages(sp?)? I want to change Speedometer, Tach, Oil Pressure, Fuel, Volt and Temp Guages. Also, what would be an acceptable set of Shocks and Struts for not too much money. Mine need to be changed, but I have so many things I need to pay for (still paying off some of engine swap, etc.). Thanks...
Old Oct 14, 2002 | 12:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You mean you want to take the gauges out of the current dash and put new ones in? Can't really be done; you're going to have to make a custom dash panel. All the gauges are built in to the dashboard; they're not separate "pods" like you'd buy from Autometer. If you do some searches (or post a message) on the Body/Interior boad, you can get quite a few cool pictures of actual home-made dashbaords using real Autometer gauges. They all look really impressive!!
As for shocks and struts, pretty much anything you buy will be better than what you've got now, especially if you're riding on the original units from 1989. No matter which one you go for, even if you get the cheapest, you'll notice a hell of an improvement. I think Summit is selling rear KYB shocks for $20 and front KYB GR-2 struts for $60. (Can get the KYB adjustable front struts, the AGX series, from Summit, for $100 each).
Old Oct 14, 2002 | 07:02 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Thats a really good price on shocks and struts. 160 american (250 cand) isn't bad for suspension work.
Old Oct 14, 2002 | 07:30 PM
Belker's Avatar
I got the KYB shocks and struts over a year ago from Summit and have been happy with their performance (although I admit I know nothing about a true perfomance suspension). If you've never done it, replacing the stocks was really, really easy. I, however, let my alignment guy do the struts,
Old Oct 14, 2002 | 11:34 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
what's wrong w/struts
I rmember laying on the ground & using both legs to kick the craftsman 2 1/2 foot 3/4" breaker bar 50 billion times on the drivers side to get those damn bolts to move, & then put a wrench on to actually remove the bolts wen broke loose. The pass side, I was hopping on that damn breaker bar , also another 50 billion times. Just make sure you don't remove the tie rod first Also a good time to do front break job.
Old Oct 15, 2002 | 01:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, torque spec for those front strut-to-spindle (aka steering knuckle) bolts is 180 ft/lbs!! My torque wrench only goes up to 150 ft/lbs. And fuhgetaboutit if you've ever jumped a curb with the car; the strut-to-spindle bolts could be BENT, and they'll barely turn at all. The nut will come off but you'll need to take a BFH (big f'in hammer, for those that haven't used one yet ) to the bolt to knock it out. And watch out for that spring so it doesn't fly free and kill ya!
Old Oct 15, 2002 | 12:07 PM
92RSMuscle's Avatar
gas rider shocks and gabrial struts....the best
Pac J
May 17, 2020 10:44 AM
RedLeader289
May 28, 2019 01:47 PM
MadOTC
Oct 13, 2015 04:46 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
