If I go V8?
Old Nov 3, 2002 | 02:39 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
If I go V8?
when i go to do the suspension and stuff, like new shocks springs, etc, can i use the V8 parts? or is there something different with my car, like a STB is made for the V8 are my towers a little bit different or something??
Old Nov 3, 2002 | 02:42 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Not that I know of... an FBody chassis is still and FBody chassis.
Old Nov 3, 2002 | 05:32 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
when changing your suspension over, use v8 parts. The cars are identical, the differences that you'd encounter would be with motor mounts and tranny mounts. Tranny mounts should bolt in directly, but are different in style. Motor Mounts are placed differently on the frame, but the frames drilled for them already. V8 springs are stiffer up front to support the greater weigh, w/o v8 springs in a v8 car, the front end would slouch slower, and handle worse. Rear springs aren't all that different, but, a good idea would be to stiffen up the back to, because emmense torque (if u build a strong 8) can slam the rear end on the ground in a heart beat, (known from experience in my friends LS1 thirdgen).
Old Nov 6, 2002 | 06:30 PM
lankchevy_350's Avatar
did i read that right? ur friends ls1 thirdgen?
Old Nov 6, 2002 | 07:12 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I've seen one of those at the T/A Natls @ Dayton this year. was in a camaro. One of the sponsors up top had the car, i forget which one... maybe thirdgenresource
