um help please???
Old Nov 23, 2002 | 05:27 PM
ionicswing's Avatar
um help please???
Ok i have a 3.1, and it smokes/maybe steams,but anyway it hasnt leaked oil or transmission fluid, and the smoke like stuff is comeing from the end of the engine behind the fuel injection system, does anybody have a clue what it is???
and it does leak water some where, could that be it??
Old Nov 23, 2002 | 05:45 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
sounds like blown head gasket but.........
when does it smoke, what color, ant drivability probs?
Old Nov 23, 2002 | 05:57 PM
ionicswing's Avatar
when the engine is sorda warm, and the smoke is whittish!!
Old Nov 23, 2002 | 08:43 PM
KED85's Avatar
Reality.
You may have internal damage & it's gonna be going shortly.
ONE WAY TO TELL
Have the water system pressure tested to see what may happen.
Good luck,
BUT sounds not good.
High milage engine over 150,000 miles?
IF YA GET BAD NEWS
SERIOUSLY CONSIDER THE ALTERNATIVE TO REPARING THAT SPECIFIC ENGINE UNDER THE HOOD>.
Engine swaps are dirt cheap keep it running solutions.
That's how I use the 3.4 mills.
Good luck
