Global West Steering Brace aka Wonderbar
Old Dec 26, 2002 | 10:40 PM
JoshDT91's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 2.8L V6
I just installed a Global West steering brace on my 2.8 now it smashes the lower radiator hose. However, I drove it up and down the road a while getting it hot and it did not overheat. It stayed around 160 and it only got hotter than that when sitting in the driveway idling. I am just curious if anyone else has installed Global West's wonderbar on their 2.8. If anyone has could someone show me a pic of it on their car or if you had trouble? Thanks guys.
Old Dec 26, 2002 | 11:24 PM
AFreaknGoodTme's Avatar
I removed the plastic hose brace and strap next to the lower radiator inlet, then I cut off about 3-4" of the lower hose near that funky bend and it fit snug against the steering brace but no longer distorted the shape of the hose any. Mine is a Global West unit also.
Old Dec 27, 2002 | 07:17 AM
JoshDT91's Avatar
Engine: 2.8L V6
I was thinking of that, I just wasn't all about losing a ton of coolant in this cold weather. I guess I could try that when it gets warmer. Do you have any pictures?
Old Dec 27, 2002 | 07:34 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have a Top Down Solutions one and it "interfears" with the lower hose also.
From what I have read, any stearing brace on our cars will.
I would be intrested in where you cut the hose also to make it function better.
Old Dec 27, 2002 | 02:34 PM
Camar_Hunter_c's Avatar
I have a factory Wonderbar on my 92, and no interferrance.
Old Dec 27, 2002 | 10:10 PM
JoshDT91's Avatar
Engine: 2.8L V6
Camar_Hunter_c:
Do you have a 3.1L, if so it won't interfere with the hose because it is routed differently than the 2.8L. See this post for pictures for the 3.1 and 2.8. https://www.thirdgen.org/techbb2/sho...0&goto=newpost
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
Night rider327
Sep 25, 2015 04:19 AM
