V8 fuel pump
Old Jan 3, 2003 | 01:26 AM
F585's Avatar
V8 fuel pump
I noticed some of you guys have V8 fuel pumps I just wanted to know what are the benefits of doing this mod?
Old Jan 3, 2003 | 01:39 AM
AFreaknGoodTme's Avatar
Re: V8 fuel pump
The pump pressure makes no diference if the regulator is set lower. A 100 psi plastic gear V8 pump and a 125 psi metal gear Vette V8 pump both hooked up to a 40 psi fuel pressure regulator will still both read 40 psi at the injectors. I opt for the A/C Delco Vette pumps with the metal internals only because they last longer.
Old Jan 3, 2003 | 01:48 AM
F585's Avatar
alright thanks.
Old Jan 3, 2003 | 01:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You get more fuel flow with a v8 pump, but like was said, our v6's won't really notice it. That being said though, when I drop the tank (for a 3rd time!) to weld in a new right rear quarter panel, I'll be yanking that Borg-Warner pump and putting in a GM/AC pump for a v8 TPI.
Old Jan 3, 2003 | 08:01 PM
F585's Avatar
Wish I knew that last may wen my pump went out
Old Jan 5, 2003 | 05:28 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
i would use a vortec truck pump that is what iam puting in mine. it fits and flows enough fuel to run a big block truck. certainly it is more than enough for anything you can do to the v6 and it will still work if convert to small block injected v8 making over 400hp.
Old Jan 5, 2003 | 06:05 PM
Ovrclck350's Avatar
You do know that the MPFI V6's and the TPI V8's use the same pump though, right Tom? Therefore, there's NOT any extra flow.
Old Jan 5, 2003 | 06:17 PM
1986CamaroSC's Avatar
Car: 1986 Camaro SC
same thing i was thinkning, and if it was from a carbed V8 the regulator would be set down like 10-15psi wouldn't it?
Old Jan 5, 2003 | 08:55 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Takes same pump. Hum thats funny
1991 3.1l v6 mpfi
Fuel pump
e3240
ep240 are choices
1991 5.7l v8
fuel pump
e3210
ep241
And when I got mine last week, counter guy recommend v8 pump to me as so does most on this site recommend.
Old Jan 6, 2003 | 08:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Re: V8 fuel pump
AFreaknGoodTme, could you give a MY for the Vette pump that will fit? I'd think a '90 or '91 would but you never can tell.
Thanks,
RBob.
Old Jan 6, 2003 | 10:20 AM
Re: Re: Re: V8 fuel pump
Thanks,
RBob.
"MY"?
The pump I used is out of an '89 Vette. I first used one in my '89 Chev truck, the stock one was 100psi w/plastic gears, and the Vette one for that years I was told is a 125psi with metal gears. The pressure I can not verify but can tell you that they do have metal internals. Needless to say I recently decided to use the same A/C Delco '89 Vette pump in the Camaro also- works great, and didn't have to mess with the fuel pressure reg. at all.
Old Jan 6, 2003 | 11:21 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Re: Re: Re: V8 fuel pump
"MY"?
Then the '89 it will be. MY, model year.
RBob.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
