Attn: 3.4 Swappers - Report for Review!
Old Jan 4, 2003 | 02:59 PM
KED85's Avatar
Many know, I've coached (written the "book"-tho not the "author" as I really tip my hat to Mike Knell of JTR for that honor) the 3.4 swap projects on our rides, by personal reply emails & reply comments here on the V-6 side.
Since I did my first 3.4 swap (to my 1985 Firebird) back in Jan of 2000, my trials & errors have brought many "Beware of this Detail" suggestions for other 3.4 swappers.
My first obvious trial and error involves loosing the auto tranny, due to a poor previous rebuild.
Solved by a decent rebuilt tranny job.
One 3.4 swapper, ate his clutch (only one stick 3.4 conversion reported, so far, CaliCamaro will make 2!-SOON!!!). Upon replacing his clutch, no problems, since.
For helping other 3.4 swappers now & in the future, how about responding and offering your personal 3.4 swap trials & errors, to avoid those "Speed Bumps".
Hopefully, our real world experience will make a shorter return to the road for enjoying more "Miles of Smiles".
The point is also to help keep your ride "Smog Legal", too.
Hope this provides informative reading, Q's & A's, for many!
Old Jan 4, 2003 | 04:33 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
make sure that the tranny lines running under the engine are disconected from the clip attached to the oil pan before attempting engine removal
AND
Make sure all bolts & nuts are separated between the 2.8 & the 3.4 :nono:
Old Jan 4, 2003 | 08:19 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Since mines not a "normal" swap for many, but, I will do my best when questions are asked.
So far, I haven't had to many issues. Just glad my pops informed me of the poilot shaft bushing since it came from auto car, to manual truck.
Other then that, not to many issues.
I know I will get many when mine starts, and then I'm hoping for :hail: :hail: :hail: at the car shows, maybe a few also
Old Jan 4, 2003 | 09:01 PM
86camarodriver's Avatar
Re: Attn: 3.4 Swappers - Report for Review!
I knew a guy in Oklahoma that did the swap with the 5 speed, I do not think he had any problems. His screen name is StewPCN on AOL IM
Old Jan 4, 2003 | 09:40 PM
Engine: 5.7 / 7.4
Dale is doing the 2.8-3.4 swap boogie ver. 3.0
Ver 1- reusing all 2.8/3.1 accessories
Ver 2- using 3.4 accessories
Ver 3- Complete 3.4 swap including manifolds, coil paks, ecm, etc....
what will Ver 4 be?....put a third gen body on a 4th gen V6 bird?
Old Jan 4, 2003 | 10:13 PM
Dale's Avatar
Engine: 350 S-TPI
Close project!!!!
Reusing headers that were on the truck. I am having (better off) to put the 3.1l fuel rail in it though.
Old Jan 6, 2003 | 10:24 AM
my91rs's Avatar
Car: 91 RS
Engine: 3.4L
BE SURE ALL OF THE INTAKE BOLTS ARE OUT BEFORE TAKING OFF THE INTAKE. OR YOU LL END UP W/ A BROKEN SCREW DRIVER TIP DWN IN THE HEAD LIKE I DID. IF YOU RE PULLING IT FROM A DONOR CAR.
F-body-fan
Jan 12, 2023 01:49 PM
ULTM8Z
Oct 2, 2015 01:25 PM
92projectcamaro
Sep 29, 2015 07:07 PM
