How much?
Old Feb 16, 2003 | 03:40 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
Convert an auto to a manual
I got a bird w/ the 2.8 and the 700r4 and my first intentions for her were the 305/TH350 combo in the garage but my 2.8 is running really strong and beats some 305s. So i was thinking maybe swapping in a T5 would be better i doubt im gonna drop a v8 into her ive grown attached to the 6 but i want a manual. What do i need? heres my idea
-T5 tranny w/ 60* v6 bellhousing
-tranny mount maybe?
-driveshaft maybe?
-Clutch and brake pedals
-shifter
-Master cylinder out of a manual car
-Manual steering column maybe?
and how much does this swap ussually cost? and is it possible to do without a lift?
thanks any experiences , pics anything would be appreciated
Old Feb 17, 2003 | 05:00 PM
TTT come on someone here has had to do this .. im not looking for instructions as i am experiences .. money and time , also was it worth the swap?
Old Feb 17, 2003 | 08:04 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
One guy has done the swap since I have been on boards. Might want to put new post with topic like "convert auto to manual" to get better response.
Old Feb 17, 2003 | 09:14 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
get an ecm for the manual. It's best to find a donor car & take everything at once. If you can, drive your car to the salvage yard, & then right beside it, so you can see where everything will go & take notes. I remember reading about this being done, maybe a year or two ago, when I first started posting.
tranny crossmember might be different. you're gonna have clutch master & slave cylinders. don'y quit understand about the steering column though
Old Feb 18, 2003 | 11:24 AM
The steering column in my manual trans am has a little metal lever that ya pull up to take the key out cause there aint no park
