Can someone tell me the p/n for a coil?
Old Mar 28, 2003 | 10:23 AM
NHRATA01's Avatar
A coil for an '89 2.8...is it 1115315?
Thinking about changing my coil at 112k miles. Wires, cap and plugs are all fresh, still got a bit of a rough idle and figure a new coil might be in order too. For 28 bucks of gmpartsdirect, worth a shot.
Old Mar 28, 2003 | 10:37 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Well GM's are good...
However, if I were you, I'd take the opportunity to upgrade to an MSD or Accel
Old Mar 28, 2003 | 11:08 AM
ND4SPED's Avatar
in summit, the part # for the msd blaster 2 coil, which is what i have, is msd-8203 for stock ignition, and msd-8202 for msd ignition, i highly reccomend putting an msd 6a ignition in with the new coil, it works wonders, the part # for that is msd-6200. you can check out summit at www.summitracing.com they're good i buy everything from them
trev
Old Mar 28, 2003 | 11:47 AM
NHRATA01's Avatar
Thanks for the advice, but I'm really not looking to dump extra money into the car upgrading the ignition system, just wanted to replace what I figure to be a tired stock unit. The car is actually my winter car, already got one car with enough go fast parts on it to keep me happy
Old Mar 28, 2003 | 11:50 AM
NHRATA01's Avatar
Actually I see that p/n 8202 looks like its an OEM replacement for the stock ignition coil. Hell for the same price i'll give it a shot.
Old Mar 28, 2003 | 02:47 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
For cheaper, go with the Blaster 2; yes, it will work with our dual-connector coils. You just have to cut a few wires; nothing on a brain-surgery level. And if it's the winter beater car, you could even use electrical tape instead of heat-shrink!
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
school boy
Oct 22, 2015 11:47 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
