can't find rpo
Old Apr 15, 2003 | 04:01 PM
firechicken_-54's Avatar
Car: 85 firebird
Engine: 2.8 HIPO
can't find rpo
hey guys. i can't find my rpo's any where, well i basicly had everything outta the car when i was restoring it with my dad, and i still couldn't find them, would they be located anywhere elese on the car on some sort of sticker
thanks in advance
peter
Old Apr 15, 2003 | 04:49 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
The RPO codes are supposed to be on a sticker on the inside of the center console. I don't know if they are anywhere else, but it's a big freakin' sticker, you can't miss it.
Old May 21, 2003 | 08:46 PM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
If it's not in the console, it could be located in the back compartment.
Old May 21, 2003 | 11:07 PM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
If all else fails, and you can't find it anywhere, go to your local GM dealer, at the parts department. Give them your VIN #, and they should be able to print out the original RPO codes for you at no cost to you. They were more than helpful with me on this. My RPO sticker disappeared a long time ago, and they printed me out all the RPO's for my car with no problem.
Old May 21, 2003 | 11:42 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
QTA, did they give you the descriptions of the codes, too? Or was it just a list of codes, one after each other, like the original sticker?
Old May 23, 2003 | 01:21 PM
sorry it took so long to reply. They couldn't get me an actual replacement sticker, but they printed out the codes on paper, there was no description of the codes, they were printed out just like they were on the original sticker. However, the guy there gave me a code book so I could decode them myself. Of course, I left it in my car and we had a heavy rain and my T-tops leaked , so now I have to let it dry out a little bit.
Old May 23, 2003 | 01:51 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Mine were stuck to the rear "storage compartment" lid.
I have done the vin to dealer (with another car), and they printed out list. Mine gave the orginal color of the car, options, etc etc. Was very nice. Although, the car was stock, it proved to an phone order company (back in 97) that the car was actually a 93, but painted with a 94 color paint code FROM GM.
Old May 25, 2003 | 05:24 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
they charge u to get an rpo list from the vin at a dealer?
Old May 28, 2003 | 01:59 PM
No they didn't charge me a cent to have it done. They were actually pretty helpful with everything I asked them.
Old May 28, 2003 | 10:27 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Here's mine
not every code on this sheet is in the decoder here at the site.
Old May 29, 2003 | 01:35 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
that looks a lot more like a build sheet or something from the dealer? actually, was it supposed to be something from the dealer (it's a lil' late and i'm waaaay to tired to be reading). I have my RPO sheet around here somewhere, but can't find it....grrrrrrr , but i'm pretty sure it's in the room, i also have the sheet i found in the bone yard of a black 85 firebird trans am WS6 car, wow, i should go get that vin from that car too and plop em both in mine, suddenly i'd be set w/ my 85 firebird to trans am conversion. LOL. Lots of the RPO's would have probably matched up to, minus the engine suspension stuff of course, both auto's with same interior, same exterior color , except my second color was black and that one was a black and gold t/a.....oh the possibilities.
Whata69
Mar 2, 2016 06:34 AM
350 IROC-Z
Camaros Wanted
Dec 18, 2015 03:58 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
rjcme
Sep 5, 2015 01:23 PM
