DUAL SNORKAL WERE DO i?
Old Apr 20, 2003 | 07:58 PM
92 RS JD's Avatar
I AM PUTING A AIR CLEANER OFFA TPI ON MY 92 RS 3.1 WERE DO I PUT THE SENSOR THAT PLUGS IN TO THE OLD ONE.DO I PUT IN THE WHOLE ON THE NEW ONE.ALSO WHAT IS THE BEST EXHAUST FOR MY 3.1ALSO WHAT WOULD BE THE BEST PART FROM THE MOTER TO THE AIR CLEANER:lala:
Old Apr 20, 2003 | 08:17 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
yup goes into the threaded hole on the new snorkel
i prefer OEM stock exhaust for V6's anything else sounds annoying
(dont ask me how i know)
Old Apr 20, 2003 | 08:41 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Welcome to the boards,
I like a my exhaust alot, I have the piping set up stock with a 36 inch glass pack. I like how it rumbles while ideling, and at speed it sounds great.
On a side note, I wouldn't type everything with caps turned on. It means your yelling, I AM YELLING RIGHT NOW WOO HOO. So please type normaly, thanks.
Old Apr 20, 2003 | 09:18 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I did this swap, yes, it threads right in. However, you will have to extend the wires. Solder them if you can. Butsplices don't work to well on sensors.
91 SrS
Oct 7, 2015 04:32 PM
zman1969
Oct 1, 2015 11:09 AM
