V6 fuel inj.
Old Apr 27, 2003 | 01:48 PM
E-Z Rollin's Avatar
V6 fuel inj.
The MPFI on 2.8's is batchfire ? and SFI on a 3.4 is sequential fuel inj. ? I don't have info. on these specific systems but on FI in general and it states:Both are port fuel-inj; Little if any difference in peak power but sfi gives better mid-range power and response,emissions and fuel economy . Is the 3.4 open loop or closed? Do you know of a publication that give detail knowledge on either of these systems?
Old Apr 27, 2003 | 02:00 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
2.8/3.1 - Batch fire, open loop till O2 is warmed, then closed loop.
3.4 SFI - Sequential setup... same looping as the 2.8/3.1
Old Apr 28, 2003 | 08:36 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
As far as I've ever heard, any fuel injection system, or any carbureted system that uses a computer, will have an oxygen sensor, and will have closed loop functionality. Was there any injection that didn't? Maybe the old mechanical injection?
Old Apr 29, 2003 | 06:23 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
There's also a mandatory engine temp for closed loop operation, around 150, if I recall.. it's been a while.. I usually assume with my 8 that it's closed loop when the converter starts locking up.
Old Apr 29, 2003 | 06:25 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The 'ol GM service manual says that the coolant temp has to be at least 70 degrees, and the computer must see a changing value from the oxygen sensor. For those that don't know, until an oxy sensor warms up, it gives off one value. So when the computer sees a changing value, it knows the oxy sensor has warmed up enough to allow for closed loop operation.
Old Apr 29, 2003 | 06:32 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Tech...your converter is dependent on your coolant temp?? Mine locked no matter what...as long as the speed was high enough in either third or fourth gear...
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
