cam and roller rockers
Old May 16, 2003 | 01:51 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Could somebody please tell me what exactly i will need when i do this swap, you know like additional parts or hard to find tools. I am planning on using the powermax 2030 cam and magnum 1.6 roller tip rockers.
Old May 16, 2003 | 02:19 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Valve cover gaskets?
Timing gasket set. Might as well chance the timing chain, and rebuild the distributor with a new pickup coil. New wires/plugs/coil, while you're at it.
I'd prolly rebuild the heads, too. New gaskets, springs, guides, locks, seals. That's just me tho.
Old May 16, 2003 | 02:24 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Taller Valve covers.
Valve Cover gaksets
Intake Gasket set
timing chain gasket set
I belive the 2030 comes with new lifters.
I agree with doward on the distrib rebuild, only another hour or two, and like 15-20 bux.
Inspect timing chain before you take it off, install a new one if remotely question it.
Old May 16, 2003 | 04:35 PM
so i don't NEED gaskets, springs, guides, locks, and seals.
at jegs
ok so at jegs they come with lifters.....any idea what kind of lifters they are?
Old May 17, 2003 | 12:58 AM
Doward's Avatar
Probably hydraulic. :lala:
Naaah... they're solid lifters. Yeah...
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
