MAP sensor
Old May 28, 2003 | 09:47 AM
ProCamaro1's Avatar
MAP sensor
I've got a code 34 on my 1987 V-6 Sport Coupe, should be the MAP sensor. Where is it located? I've changed them on V-8 cars before but can't seem to locate it on the V-6.
Old May 28, 2003 | 11:26 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: MAP sensor
Your '87 has a MAF, no MAP. Look for the MAF inline with the air intake.
RBob.
Old May 28, 2003 | 11:32 AM
ProCamaro1's Avatar
Rob,
Thanks for the reply, do you know if code 34 relates to the MAF instead? Thanks
Old May 28, 2003 | 12:35 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Yes it does---
Code 34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
An MAF that's acting up fairly bad....the car will usually run better if you unplug it. That's a quickie test. TomP wrote up this whole MAF test chart and stuff.....it's on the site somewhere...it's very in-depth if I remember right. You can try doing a search.
Old May 28, 2003 | 02:18 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
With the car idling, lightly tap on the MAF with a screwdriver or such- if the cars idle jumps all over that place when tapped on, then its definately bad.
Old May 28, 2003 | 05:14 PM
ProCamaro1's Avatar
Thanks for all the replies, I appreicate it. I got my test light and voltage meter and went through the Chilton steps and it tests for bad MAF. I'm getting ready to bolt it now.
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
efiguy
Sep 27, 2015 01:30 PM
