help!!
Old Jun 5, 2003 | 12:07 AM
3.492rs's Avatar
Car: 89 IROCZ
Engine: L98 4150 carb
Transmission: Transgo 700-r4
Axle/Gears: 10 bolt/3.23
help!!
hey its me again i need some help with my car there is a loud rattle when the car is idle around 600-700 rpms when it idles lower or higher than that it stops, but comes back when it idles around there again. the sound is coming somewhere in the engine compartment. any help would be appreciated.
Old Jun 5, 2003 | 05:24 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
sounds to me like you've got an exhaust rattle, have you tried getting underneath the car and shaking it to see if it's in place properly?
Old Jun 5, 2003 | 09:19 AM
nicki's Avatar
My 88 Camaro had a similar problem recently. Yes, you should check your exhaust. Especially the catalytic converter. In my case, the heat shield was a little loose and just needed some tightening. Because the cat is closer to the front of the car, this may make the rattle sound like it's coming from the engine.
Old Jun 5, 2003 | 10:57 PM
3.492rs's Avatar
Car: 89 IROCZ
Thanks guys i looked at my exhaust today saw it rattlin around, so im gussing thats it.
Old Jun 5, 2003 | 11:05 PM
KED85's Avatar
That'll be $.05 please!
