where do I buy???....
Old Jun 8, 2003 | 11:26 PM
bes217's Avatar
I have heard that some people are using a jamex strut tower brace successfully with the V6. If this is the case where can I buy one. I am doing all of my suspension with performance handling in mind so I want to stiffen up the sloppiness as much as possible. If there is a different kind of strut tower brace that I can use with my V6 I am open to ideas. Thanks a lot in advance.
Old Jun 8, 2003 | 11:59 PM
Ovrclck350's Avatar
Dunno if you can find one new again unless they have a web site, but what happened last year is some guy had 500 of them on Ebay for $30/piece.
I had mine on my V6, but it's on my 8 now.
Old Jun 9, 2003 | 12:09 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
I run an Edelbrock 3pt TPI brace on my MPFI V6 '87 Camaro. Fits perfectly.
You might want to use Edelbrock TBI brace however for a carbed V6.
You can see it partialy in the pic below.
Edit; ill try another pic- see if that works, sorry
Old Jun 9, 2003 | 01:21 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Where'd you get the STB?
Old Jun 9, 2003 | 01:22 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Summit racing
Old Jun 9, 2003 | 01:56 AM
Doward's Avatar
$130 for the STB? Sorry, I'd toss in another $50 or so and get the Spohn Subframes first - that'd tighten the WHOLE body, instead of just the front end
Old Jun 9, 2003 | 07:49 PM
Ovrclck350's Avatar
A Good 2.8....where did you get the silver stut tower caps (don't know the real term). Any advantage over the stock ones?
Old Jun 9, 2003 | 10:15 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
They are actually not caps or covers- they are complete Aluminum replacement units for the stock Upper strut mounts. They where special production run from Hunter Motorsports (on these boards) I had them polished after I received them, most came with an anodizing option- I choose bare aluminum.
They have a replaceable Aurora sperical bearing held in place by a snap ring. Their advantage over the stock steel units is they have absolutely no flex in holding position of the strut rod {camber and caster settings hold true} The stock upper strut mounts have a large rubber dounut bushing that supports the strut rod and has flex in hard braking and cornering causing momentary camber and caster flex/change in geometry.
Sorry to say it doesn't appear that he will ever produce any more.
Here's a better pic:
Old Jun 10, 2003 | 09:18 PM
V6camaroman's Avatar
agood2.8 the edelbrock tpi brace will work ok with no clearance probs?. did u have to do any mods to make yours work? i have always been told that there isnt a strut tower brace that will work with our motors but i will take it from u because u have one. also how much was it?
Old Jun 10, 2003 | 10:52 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
It fit perfectly- bought it through Summit racing- can't recall how much it was, just check Summits' website.
Old Jun 10, 2003 | 10:54 PM
Doward's Avatar
$129.
I'd really recommend subframes before the stb, tho...
Old Jun 10, 2003 | 11:04 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
I have a BMR strut tower brace on my 3.1L. All that was custom fabbed was shims on both sides. This was in order to clear the A/C. Here's a picture.
Old Jun 10, 2003 | 11:26 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
$129.
I would agree- also, I would recommend solid strut mount bushings (like the camber kit the Ground Control sells) in place of the crappy stock rubber bushing strut mount be installed.
If you install a strut brace with stock strut mount bushings, you are not getting ANY benefit from boxing the strut towers for suspension geometry because the bushings are still flexing- thus making the strut brace useless.
Here is another pic showing the brace (with crap sitting on top of it) Its not shimmed at all- The car is an '87 Camaro. I have heard that the Edelbrock STB I have will not work on Firebirds- Best to use the BMR for the Firebirds.
Old Jun 11, 2003 | 08:07 PM
bes217's Avatar
Man those HMS strut mounts sure are beautiful. I wish I could get them for my car.....
But since they are not produced anymore I guess not.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
RedLeader289
May 28, 2019 01:47 PM
loud91rs
Oct 5, 2015 10:05 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
