5speed gear ratios
Old Jun 10, 2003 | 06:41 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
5speed gear ratios
I cant seem to search the site, and find out what the gear ratios are for the 88+ 5speed for the v6, anyone here have them, or can point me to the posting that shows them.
Damn search button requires 3 letters to make a "word"
Old Jun 10, 2003 | 09:52 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I know, I hate the Search on here.
it's
4.03
2.37
1.49
1.00
.76
Old Jun 11, 2003 | 06:37 AM
Dale's Avatar
Engine: 350 S-TPI
Sweet :rockon:
Now I gotta find someone that will give me the specs on a 4th gen one so I can make my decision.
Old Jun 11, 2003 | 09:24 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
That's one hell of a nice first gear... If only second wasn't so far spread!
Old Jun 11, 2003 | 11:45 AM
Doward's Avatar
4th gen V6 should be the same - don't know about the 3.8 equip'd rides, tho!
Old Jun 11, 2003 | 11:48 AM
Dale's Avatar
Engine: 350 S-TPI
actually, had my woman do some searching for me for that 4th gen, she found some more info on 3rd while she was at it.
89 lb8
as doward posted
90-92 LO3
1. 2.95
2. 1.94
3. 1.34
4. 1.00
5. .63
93-95 L32 (3.4l 4th gen)
1. 2.95
2. 1.94
3. 1.34
4. 1.00
5. .74
So from my understanding, the 89 one has the lowest low, and highest high correct??
Old Jun 11, 2003 | 12:07 PM
Doward's Avatar
That should be 82-89 V6 T5s..
Tho '88+ are World Class (stronger)
Old Jun 11, 2003 | 12:35 PM
Dale's Avatar
Engine: 350 S-TPI
Right, thats why I'm saying 89. We don't want any stinking n/wc's.
Anyone know where theirs a 1989 t5 forsale at? Decent price too!!
Old Jun 11, 2003 | 01:36 PM
Dale's Avatar
Engine: 350 S-TPI
I just realized something.
LO3 is not the 3.1l, it is LH0.
So now I'm stuck back at kinda square one. However, I do know for a fact that I can not use a 4th gen, the splines to the clutch are different. Also uses larger clutch itself.
So, is their a difference between the one that the 2.8l used, and the 3.1l used??
Old Jun 11, 2003 | 10:20 PM
Doward's Avatar
Shouldn't be...
WTF?! ARE YOU SURE THE 3.4 4th GEN'S USE A DIFFERENT CLUTCH?!
BRB!!!
Old Jun 11, 2003 | 10:30 PM
Doward's Avatar
HOLY ****!!
Someone PLEASE correct me if I'm wrong!!!!
4th gen 3.4 uses a 9 11/16ths clutch disc, 26 SPLINE!!!
I don't think I need to tell anyone the implications of that.
KED85, will a 3.4 Flywheel bolt to a 2.8? It's neutrally balanced. If so, (or hell, even if not - the 3.4 swap I KNOW would bolt up).
Anyone know what this means? Using a 4th gen clutch kit, we could bolt up a 26 splined transmission.
Does the word 'Tremec' mean anything to you?
Old Jun 11, 2003 | 10:33 PM
Doward's Avatar
Ladies and Gentleman, unless I'm wrong, I think we've just stumbled onto the secret of bolting a V8 transmission behind our little V6s.
Granted, we don't have the power from the engine to need that kind of transmission... but who knows?
Old Jun 12, 2003 | 12:26 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
plus the problem of the bolts not lining up.
Old Jun 12, 2003 | 12:41 AM
Doward's Avatar
GM uses a standard tranny/bellhousing bolt pattern, I believe... you'd just use your own bellhousing, to the new tranny.
Old Jun 12, 2003 | 05:01 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
i know i'm new, but if our v6s don't have the power (exept for maybe downward after he adds a turbo, damn..) whats the point? just to say "yea, shes got a v8 tranny." or are there deeper roots here?
Old Jun 12, 2003 | 06:57 AM
Dale's Avatar
Engine: 350 S-TPI
Originally posted by Doward
HOLY ****!!
Yes your right, 26 spline clutch. 1.125" diameter or something.
However, the bell housing bolt pattern is different.
Yes a 3.4l flywheel/clutch plate interchange. Its that the pre 88 are external balance, where 89 up is internal.
Tremec bought the design of the t5 from borg-warner.
In my current application I need to stick with the 14 spline, and the bellhousing I have for my slave cylinder.
If I helped anyone else think of some swaping to do, glad I could help :lala:
Old Jun 12, 2003 | 10:57 AM
Doward's Avatar
I understand the bellhousing bolt pattern is different between the V6 and V8 engines... my question, is what about the tranny bolt pattern?
Old Jun 12, 2003 | 11:24 AM
Dale's Avatar
Engine: 350 S-TPI
OOO Ok, unsure of that myself. Would require some checking.
Are you talking useing a newer (93-95) t5 inplace of an older one?
Old Jun 12, 2003 | 12:04 PM
Doward's Avatar
That, or -
Using a TR 3550 or TKO in place of the T5!
Hotrodboba400
Dec 10, 2019 07:07 PM
88rscamar0
Sep 23, 2015 09:08 PM
dbrochard
Sep 19, 2015 08:13 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
