Pully Kit
Old Jun 12, 2003 | 10:50 PM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
Pully Kit
found a pully kit, but it was for a 88 2.8, mine is an 86, will this fit, and will it be worth my money, the first part # is (49-541800) and that is just the crank pully, and the second is (49-5418001) and that also includes the alt. pully. i found these on thunderracing.com, thanks for your input
Old Jun 15, 2003 | 11:48 PM
Y2KFirehawk's Avatar
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
49-541801 ASP Pulley Set, 1988-1995 F-body, 2.8, 3.1, 3.4, 25% Crank & 23% alternator pulley set, full charge at 1100 rpm [Black Nitride]
That one from thunderracing.com includes both the crank and the alternator pulley and will fit your car just fine. But if you want just the crank pulley you would go with this one:
49-541800 ASP Pulley, 1988-1995 F-body, 2.8, 3.1, 3.4, 25% Crank pulley, full charge at 900 rpm [Black Nitride]
Obviously the one without the alt pulley is cheaper, whichever is fine, I've heard good things for both!
Old Jun 16, 2003 | 11:28 AM
BitchinRS's Avatar
How much are they charging for them? When I buaght mine I found that if went directly through ASP i got them about $15 cheaper.
Old Jun 16, 2003 | 11:34 AM
Engine: 346ci LS1
Transmission: MN6
$60 for just the crank and $80 for crank and alt. from thunderracing.com (Without s/h of course)
http://www.thunderracing.com/index.c...ategoryid=1124
Old Jun 17, 2003 | 01:09 AM
BitchinRS's Avatar
ASP is asking 64.00 and 84.00. Good deal!
Old Jun 18, 2003 | 02:33 AM
F585's Avatar
Re: Pully Kit
85-86 have 1 V-belt and 2 serp. 88 has just a V-belt it wont work.
Old Jun 18, 2003 | 08:45 AM
Engine: 346ci LS1
Transmission: MN6
Perhaps this will help you, this is where I found what belt I need for mine.
http://www.aspracing.com/belt.htm
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
bryaniskoo
Oct 1, 2015 03:18 PM
1Aauto
Sponsored Vendors
Sep 22, 2015 03:39 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
