questions from a dud!!
Old Jun 13, 2003 | 01:23 PM
1988bird's Avatar
Hi guys, extremely stupid question from a guy who doesn't know squat about engines, but is trying to learn ( and yeah, loves his car). SES light comes on intermittently in my car, comes on at times, goes off etc. driving me nuts, so figured would check the code. Haynes manual says to put jumper wire in from diagnostic terminal to ground terminal in diagnostic link, and says that code 12 will flash on CHECK ENGINE light. First question: is the SES light same as CHECK ENGINE light? if not, whereabouts on the dash is it located (i.e, RPM gauge, speedo gauge etc). Second question: If code 12 "flashes", what does that mean? Manual says one short flash followed by two quick flashes. Also says, any other codes will "flash" after that. Does that mean that the number 12 will come on like a digital readout in the CHECK ENGINE light, followed for eg, by code 32???? Thanks!!!!
Old Jun 13, 2003 | 01:28 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, SES light is the Check Engine light.
Flashing 12 means:
Flash
(pause)
Flash Flash
That's a code 12. Each code flashes 3 times, then moves onto the next. When you get back to 12, you're out of codes.
Code 12 means the distributor isn't getting any pulses- which makes sense, because the engine isn't running.
32 would come up as
Flash Flash Flash
(pause)
Flash Flash
Old Jun 13, 2003 | 01:34 PM
1988bird's Avatar
Thanks Tom! makes a lot of sense now!
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
