Compression value and tune-up
Old Jul 19, 2003 | 12:29 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
What's a good compression reading on the 2.8? I can't find a value in the GM shop manual, and the Haynes book says N/A which I hope means not available as opposed to not applicable.
And I'm doing some work on my car this weekend. New distributor, module, pick-up, rotor, cap, wires, coil, coil harness, lower rad hose, coolant flush, heater hoses... I'll let you know how it goes.
Old Jul 19, 2003 | 12:52 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Mine said 160 across every single cylinder. I think that's normal, never had anyone tell me it's not...and I took that reading after getting a valve job, so there better not have been any carbon build up in there.
Old Jul 19, 2003 | 01:04 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Mine ran 160 all the way across. it's not the number you're worried about, but consistancy between them
You want less than 10% difference.
Old Jul 20, 2003 | 12:20 AM
Thanks guys. I know that consistency is important, but to be quite honest, in all the work I've done on my car, I've never checked the compression. Never been concerned about it. But lately I've been concerned that it may be too high.
Old Jul 20, 2003 | 08:38 AM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
If it's higher than normal it's probably buildup in the combustion chambers/on the pistons.
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
