est sensor
Old Aug 3, 2003 | 12:14 AM
PONTIAC86style's Avatar
Car: Pontiac Firebird
Engine: 2800
Transmission: slushbox 700r4
est sensor
What are symtoms from a bad knock sensor or solenoid? also...... would a bad tps cause studderd shifting when under heavy throttle, without and codes and no ses light? thanks for input.....
Old Aug 3, 2003 | 02:00 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't replace your knock sensor or solenoid!!!
Because you don't have one!!!
That's only for 90-92 3.1's with speed density...
Yes, bad tps = bad idle quality so it might cause funny shifting. Need to throw a digital meter on it, check first for the correct tps setting at closed throttle.
Now throw an analog meter on it. Don't hook the meter up like you're reading the computer (like you do when you check tps voltage at idle). Analog meter on ohms- one probe to the center terminal of the TPS. Second probe to one of the outer terminals. Move the throttle linkage. The meter's needle should swing smoothly- no jerky motions. Jerky motions = bad tps. Can't be done with a digital meter (unless the digital meter has an analog bargraph readout like my Fluke 73) because you need to see a steady increase in voltage- digital just shows you numbers.
Old Aug 3, 2003 | 08:47 AM
Engine: 2800
is it possible to adjust your tps for peformance? or is it just to keep the stock specs in order to keep the motor running at its possible best?
Old Aug 3, 2003 | 08:48 AM
Engine: 2800
also, no knock sensor? what do i have instead? nothing? or is it somthing in the computer?
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
