got a ?
Old Nov 1, 2003 | 08:54 PM
jlbolin's Avatar
got a ?
just a ? a friend of mine has a jeep w/a 208 v6 .i was told it was a chevy 2.8 cause back then chrysler was using gm 2.8 in there jeep trucks. now if that is true then can a 3.4 out of a 95 camaro be put in there.the 2.8 is tired and instead of rebuilding it i recomended getiing one from a junk yard.found one for 500 at 86000. his jeep is an 85 and its carbureted. dont flame me for it just asking .trying to help.
Old Nov 1, 2003 | 09:23 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
If its a GM RWD (motor mounts position) 60* V6 block, it will work.
Old Nov 1, 2003 | 10:35 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
did u mean a jeep 2.8 v6...I can't seem to find a 208 anywhere I would think that as long as its a 2.8 in there now, you could slide a 3.4 under ur 2.8 intake just like has been done so many times on this site
Old Nov 2, 2003 | 12:07 AM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
As long as it's an actual RWD GM 2.8, the RWD GM 3.1 and 3.4 will swap right in quite happily.. however, proof of it being a RWD GM 60 degree to begin with would be found through serious web searching, which you are more than capable of doing yourself, hence I'm not going to do it for you...
http://www.google.com
Old Nov 2, 2003 | 12:14 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Wan't Jeep still produced by GM back in 85? I know it was part of the AMC division of GM, and that was sold to Chrysler in the 80s, but what year it was, I have no idea.
Old Nov 2, 2003 | 01:18 AM
jlbolin's Avatar
it looks identical to my uncles 2.8 in his 86
s-10 ,, my cousin has a 89 jeep comanchee and it had the same 2.5tbi enginge the s-10s have
Old Nov 2, 2003 | 06:05 AM
Sparkchicken84's Avatar
easy way to make sure look at like part#'s for cams piston gaskets all the same so the 2.8 jeeps and 2.8 f-bodys, s-10s are all gm rwd 2.8s
