Carbon build up...
Old Dec 8, 2003 | 01:00 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Carbon build up...
What do you guys suggest to get rid of this crap??? I got a motor that is pushing 210 psi on the compression check, and it gets there very quickly. The service manual says taht it should be arouns 150 psi. I've heard in the past that Sea foam is the way to go, but I can't find it out here in Los Angeles? Any other fun forms to remove it???
Old Dec 8, 2003 | 06:31 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Napa or Carquest carries Seafoam.
Or go to a GM dealer, and ask for their 'GM Top End Cleaner'
Otherwise, a wire brush works well, just don't do that on the pistons.
Old Dec 8, 2003 | 07:05 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I did the sea foam on mine, and fowled out some plugs, so after you do it, plan on changing plugs.
Old Dec 8, 2003 | 08:12 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
NAPA sells a fuel injection intake cleaning kit which is supposed to clear out everything from the throttle body to the chambers themselves. I have yet to try it, but I heard it works.
Old Dec 8, 2003 | 12:09 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
laeve it alone if its not lose and rattling around. it'll bump up your compression ratio a little and, on a N/A motor, more compression will help power. if you really want it cleaned out, what about the water method? spray a light mist into the intake.
Old Dec 8, 2003 | 09:10 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
well. the carbon build up has raised my reading on the compression gauge from 150 to 210 on every cylinder and I MUST run 91+octane boost for it not to ping. I've done everything short of actually removing the head, and everything else is within spec. I wouldn't mind so much, but having to run 91+a bottle of octane boost isn't good.
Also, I have already tried the water trick...didn't work. made a little bit of grey smoke, but nothing major. This engine is 20 years old and never been apart except for a valve adjustment, so it's tired.
p.s. this isn't a f-body motor, it's from a volvo, but I knew that you guys would have an answer for me.
Old Dec 8, 2003 | 09:47 PM
Engine: 2.7L V6
Axle/Gears: 4.41
Having a nice coolant leak at the head gasket works wonders too. It ruins the head so it has to be machined, but the engine internals are clean as a whistle on my dad's 2.2L Cavalier...
Other than that, the best I can say is the kit from NAPA.
Old Dec 8, 2003 | 10:40 PM
KED85's Avatar
What's easier?
Paying for octane booster & pouring it or doing the dirty work & fix the engine correctly?
IF an old Volvo from late 80's they run for quite a long time.
Old Dec 8, 2003 | 11:03 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
I got my can of Sea Foam from an advance auto. Just call around the auto parts stores, if no joy, call around the boat shops
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
