Hp/Tq/Cam Questions
Old Dec 16, 2003 | 12:32 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Hp/Tq/Cam Questions
Alright, tryed searching. I suck at any search engine.
1. 3.4, is 160hp, 200tq, but at what rpms?
2. 3.1, is 140hp, 180tq, but at what rpms?
What is the STOCK cam specs for the 90-92 3.1l engine?
grr, lunch is over, their cracking the whip. Thanks for any info!
Old Dec 16, 2003 | 01:07 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Stock 3.1 cam is the same as the stock 2.8 cam - that being said, it's as follows -
I can't find the duration, but the lift is -
.393/.409" lift using 1.5 rockers... This is the HO cam, used on '86+ 2.8/3.1's
Old Dec 16, 2003 | 03:04 PM
Dale's Avatar
Engine: 350 S-TPI
ok, have searched tell my fingers hurt.
1. answer is 4600rpm/3600rpm.
2. answer is 4400rpm/3600rpm.
3. Part of answer in dowards repsonse, still havent found anything else I really need the lobe sep, duration would be nice too.
Old Dec 16, 2003 | 09:00 PM
6SPEED84Z28's Avatar
Car: 84 Z28 / 91 Trans Am
Engine: LS1 / 5.0 TPI
Transmission: T56 / 700R4
Axle/Gears: 4.09 / 2.73
the cam specs are as follows .394 int .410 exh 196@.050 int 203@.050 exh on a 109 lobe center
Old Dec 16, 2003 | 09:33 PM
Dale's Avatar
Engine: 350 S-TPI
much thank you :hail:
now I gotta tally my stuff up, and pick one.
Old Dec 16, 2003 | 09:35 PM
Dale's Avatar
Engine: 350 S-TPI
Hum, anyone ever put a cam with 107 lobe speration in a mpfi system?
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
