V6 700r4
Old Jan 23, 2004 | 01:30 PM
firefrombelow's Avatar
V6 700r4
Are the V6 and V8 700R4s compatible with each other???
Will the V6 one hook up to a V8?
Thanks in advance!
Old Jan 23, 2004 | 01:52 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
bellhousing pattern is different
input spline shaft is different.
Old Jan 23, 2004 | 02:13 PM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
that would make the answer "no" but the internals are interchangeable, so if ur building a six cylinder version, have it built w/ a v8 rebuild kit...will work just the same or better.
Old Jan 23, 2004 | 02:52 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Originally posted by 85f-bird
... the internals are interchangeable, so if ur building a six cylinder version, have it built w/ a v8 rebuild kit...will work just the same or better.
They're WHAT?! *peers at the 700R4 sitting outside* Okay.. uhm.. that thing's getting some fresh shelter today.. suppose I should move my 327 and 350 under something too..
Old Jan 23, 2004 | 04:30 PM
85f-bird's Avatar
Engine: 2.8L, LS1
yeh, on the boards when peopleare rebuilding their 2.8L 700r4, they do the rebuild with the kit labled for the v8 cars found in jegs or other car parts mags. the original sixer tranny is also not considered as strong as the 8 cylinder counterpart, but can be made just as strong as the stock 8, and also can be made stronger than it too....just like you could doto the v8 car.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
