ERROR CODE alert!!
Old Feb 11, 2004 | 08:29 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
ERROR CODE alert!!
I was driving along when my car decided to sputter and die. Luckily enough I had the code reader in my car (which i was going to return, not anymore). Checked the code and out came 42, and 54. Whats my problem?
Old Feb 11, 2004 | 08:51 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Sixbanger,
Code 42 = Electronic Spark Timing circuit
Code 54 = Fuel pump Circuit (Low Voltage)
The code 42 means you have a possible short or open ground in the EST or bypass circuits.
The code 54 means you have either a defective fuel pump relay or the fuel pump voltage is lost while the engine is running.
Old Feb 11, 2004 | 10:33 PM
sixbanger's Avatar
And this means????
Old Feb 11, 2004 | 10:55 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
This means hope that the fuel pump relay is bad because anything else is going to be a nightmare to fix.
Old Feb 11, 2004 | 11:02 PM
sixbanger's Avatar
Can i get the fuel pump relay at the parts store or is it a junkyard piece? Anyone have a pic where it's located?
Old Feb 11, 2004 | 11:16 PM
You can get a new one at the parts store I'm pretty sure. I'm not sure which one is the fuel pump relay, but there's a bank of 3 (or so) relays on the firewall right in front of the driver's seat. Buy a Haynes manual, it costs $20, and it should tell you which one is the fuel pump relay. You should be able to test it just by hooking up the correct terminals to the battery.
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
3rdgenparts
Sep 28, 2015 10:47 PM
mfp189
Sep 27, 2015 09:25 AM
