Starving for fuel????
Old Feb 12, 2004 | 11:36 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
For some reason, I seem to be running lean. The car has a hesitation too until it warms up. Timing is 20 degrees advanced (That's what it likes, thats what it gets...). Totally acting like it's not getting enough fuel though. Would an Adjustable regulator help, or am I pissing in the wind? I don't wanna have to cut out my fuel pump (It may be on its way out?). Thanx for any suggestions or advice. Oh yeah, I'm using the same regulator that was on the 2.8 fuel rail..
Old Feb 21, 2004 | 02:39 PM
[superbird]
Guest
Posts: n/a
check the fuel filter and pump
Old Feb 21, 2004 | 02:55 PM
br()bert's Avatar
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
did you swap in the 3.4 injectors?
Old Feb 21, 2004 | 07:55 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
check the pressure at the back of the fuel rail, that'll tell you if you have a pump that's on it's way out.
Old Feb 21, 2004 | 08:41 PM
FbodTrek's Avatar
Yea brobert
I swapped in the 3.4 injectors and the regulator. I think it was a dying fuel pump (changed it today, much more power).
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
mike_c
Aug 27, 2015 04:32 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
