Ahh good times....
Old Feb 19, 2004 | 01:05 PM
sixbanger's Avatar
Car: 87 Firebird (Hasselhoff special)
Engine: 2.8L of PURE STOCK POWER
Ahh good times....
I was under the car yesterday and decided to check on the condition of my cap/rotor. PO said he replaced not long ago. Spark plug wires new as well. So I take off the cap and whoa...it sure is messy under there.. It looks like he had tightened the cap down too tight so that the rotor had actually started to melt away into the cap. Interesting. I take the cap and rotor off for closer look and it looks like the cap wasn't centered over the rotor either. So there is a little groove worn into the cap that is not centered over the little carbon button in the middle of the cap. And the burn marks electrodes on the inside of the cap are all along the bottom of the electrode where it is molded into the plastic. So, i cleaned it up and will now see if it makes any difference. Damn PO!!! Is there anything I can spray on the distributor (under the cap area) to clean all the dirt and crap away with? One more thing...I checked to see if there were any sparks with car running in the dark. I saw sparks at all cylinders. Very small and faint right at where the wire clips into the plug. Is that ok?
Old Feb 19, 2004 | 01:26 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I sprayed some wd40 on mine when I got it, everything was quite rusted.
Sounds like you need a whole new cap and rotor button which is not expensive.
Old Feb 19, 2004 | 01:39 PM
RedTtop5spd's Avatar
Car: 99 SS
PB Blaster works well. I used it on my cap and rotor on my s-10's 2.8L. I'd go with Dale on the new though. It's cheap enough.
Old Feb 20, 2004 | 01:35 PM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
you shouldn't see any sparks at all. Where were they sparking to. do the wires cover the plug completely? Mine seat all the down over the plugs, plus the heat covers, so the connection is buried deep in rubber
If they sparking to somewhere other than the gap in the sparkplug, you're loosing ignition spark
Ghettobird52
Jul 5, 2024 11:18 PM
specialized
Jun 18, 2022 09:26 AM
Lmancha96
South Central Region
Oct 22, 2020 12:40 PM
MantyZ28
Jan 18, 2016 08:30 AM
ezobens
Aug 19, 2015 10:29 PM
