Fuel Pump Stuff
Old Feb 21, 2004 | 02:51 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Fuel Pump Stuff
Dangit!!!! Sonar and I replaced my fuel pump today with a Carter unit. Followed the wiring directions to a "T". I have a slight problem though....the directions were WRONG!!!!!! the way they say to wire it is obviously backwards (pump comes on, no fuel though). Appparently, the polarity is reversed. My question is, is there a good way to fix this little mistake without removing the fuel pump? Does anyone know which of the 3 wires to the connector harness do what (like, maybe just switch wires around on the harness???). Those basturds.....If you change a fuel pump and replace it with a Carter unit, wing it..... Directions are for dingbats (still havn't forgot that Chiltons crap). Thanks for any help.
Old Feb 21, 2004 | 04:47 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
How could you switch the wires up???
The gray wire is for the pump. The purple wire is for the fuel level sender. The black wire is obviously ground.
Old Feb 21, 2004 | 12:17 PM
FbodTrek's Avatar
I was thinking at the connector.?
Would that work?
Old Feb 21, 2004 | 01:09 PM
Engine: LH0 3.1L
No I meant how did you switch up the wires in the first place?? I've never installed an aftermarket pump, but howcome you didn't just remove the old pump and plug the new one in??
You need a set of connector pin removers to back the wires out of the connectors.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
