where you get new elec. connector??
Old Mar 5, 2004 | 06:48 PM
squirrelybird's Avatar
i recently replaced my ignition coil, and when i pulled off the front wire harness/connector, the plastic was so dried and brittle that the clip (that holds it on) broke right off. this is a gray connector, two wire (i think one pink or red and one is yellow?) that connects to the front top of the coil. (91). i had it held in place with elec tape, but it starting coming loose and the tach was jumping all around, so i want to replace the connector.
where do you get replacement connectors like that??? thanks.
Old Mar 5, 2004 | 06:53 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Junkyard
find a GM car from the same era as yours and open the hood , find the coil and cut the wire. Pocket it and walk out.
Old Mar 5, 2004 | 08:07 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Carquest almost certainly carries these brand new. I've gotten weird off-the-wall electrical connectors from Carquest, all of which they've simply walked off and grabbed from a shelf. Napa would be a 50/50 chance.
Old Mar 5, 2004 | 09:09 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You can try the dealer if you can't find it. They can get pretty much any connector pigtail imaginable.
Old Mar 6, 2004 | 02:10 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I think any auto parts store should have it. They are very common across GM cars as FbodTrek mentioned. I got mine from the local parts store here. One thing to check for is that the prongs inside the plug are the same length as the original. The grey one I got had shorter prongs and it caused me some problems.
Old Mar 7, 2004 | 04:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Beware though; the local pep boys charges $15/connector for those suckers. ($15 for the black one and $15 for the gray one).
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
