Distributor and Rotar
Old Apr 2, 2004 | 03:09 PM
6cyl92CamaroRS's Avatar
Car: 92 Camaro RS
Engine: 3.1 L
Today i had an extra hour so i decided to do my distrubutor rotor and wires, i got the distributor off and was trying to find out how to get the rotor off but i cant. My hanes manual said to just unscrew it but i have no idea where to do that there are no places to screw the actual rotor down do i have to take out the whole unit the rotor is attached to.
Mitchell
Old Apr 2, 2004 | 03:34 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
It just pulls off. You gotta tug HARD, and then skin your arm on the firewall lip.
Yes, its PITA, but it pulls strait up. If you have a small hammer, tap on the bottom side upwards.
Old Apr 2, 2004 | 10:22 PM
squirrelybird's Avatar
yes...scary...sharp metal cowl.....wear gloves if you have any. i think its safer if you use your forearm as a lever (using intake as pivot).
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
