size of dist. hold-down bolt??
Old Jun 13, 2004 | 09:37 PM
squirrelybird's Avatar
when i changed my distributor, i had to wrestle with a couple wrenches to get the hold down bolt off/ on. well i need to advance my timing a little, and i dont wanna mess with it. im gonna just buy one of those pre-bent distributor hold down wrenches, but save me the trouble of checking.....what size is our distributor hold down bolt???
thanks
Old Jun 13, 2004 | 09:40 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Hello Squirrelybird,
Haven't seen you around lately, how are things going? On mine the bolt head is a 9/16". Have fun!!!!!!!!!!!!!
Old Jun 13, 2004 | 10:09 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
Mine was metric, the one just larger than 9/16...I think 13mm. We ground it to 9/16 though so I could use that nifty wrench.
Old Jun 14, 2004 | 12:07 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
easy way here...
13mm socket -> u-joint socket -> 12" extension -> ratchet/driver
takes care of the issue, just get it as straight as you can...it'll work and I bet you already have these tools
Old Jun 14, 2004 | 03:27 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
You sure its 13mm? I could've sworn I lost a 15mm socket trying to remove the dist off my ex's 3.1. And I did have success with a 15mm socket... so I'm going to say its 15mm, because that's what mine is too.
Old Jun 14, 2004 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The 3.1l in '92 has a 15mm bolt head. Don't know about any of the other years.
RBob.
Old Jun 14, 2004 | 08:52 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i was thinking that mine was metric, but i couldn't remember if it was 13 or 15mm.
Old Jun 14, 2004 | 09:07 AM
TMX's Avatar
TMX
Car: 84 & 92 Z28s
Engine: 305 carb & 305 TPI
It will either be 9/16 or 15mm.
-B
Old Jun 14, 2004 | 09:16 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
all of the 6/60's I have messed with, 15mm
Old Jun 14, 2004 | 02:17 PM
BitchinRS's Avatar
It should be 15mm. When I bought my pre-bent wrench the only one the parts store had listed was for the 2.8 and they were all 15mm. The pre-bent wrench makes life a whole lot easier!!!!!! Just wiggle down there and turn. No fugging around involved.
I could not find one at chain stores like Kragen's, Auto Zone, etc. I had to go to my favorite local parts store that supplys shops with tools and parts. coast me all of $8.00 . I all ways sujest finding one these types of parts stores. They carry better quailty parts and tools. You can even find strange off the wall tools, like pivot pin removers for working on tilt stearing collums.
Old Jun 14, 2004 | 08:47 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Originally posted by 2_point8_boy
easy way here...
yup, sure is a 15mm...my bad, mind must've been on food again
tom1985
Apr 19, 2016 07:55 AM
toronto formula
Nov 10, 2015 06:17 AM
gixxer92
Sep 1, 2015 04:32 PM
355tpipickup
Alternative Port EFI Intakes
Aug 22, 2015 06:06 PM
knight72
Aug 10, 2015 09:32 PM
