Hi FLo cat?
Old Sep 17, 2004 | 10:19 AM
92RS3.1L's Avatar
Car: 91 Z28
Engine: Rebuilt and modified 350
Transmission: rebuilt T-5
Hi FLo cat?
Ok, so my Dynomax Super turbo catback exhaust is ordered and will be coming in around next week. I would like to replace my cat converter, adn I was wondering if I should go stock, or get a hi flo cat converter. Any suggestions?
Old Sep 17, 2004 | 12:05 PM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
i got a dynomax high flo cat
my high flow cat cost me $94 at summit racing part number WLK-15735
Old Sep 17, 2004 | 07:50 PM
92RS3.1L's Avatar
Car: 91 Z28
Was there any noticeable performance improvement with the hi flo cat? Or was it just louder?
Old Sep 17, 2004 | 09:47 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
cat
its coming in the mail tuesday so i dont know yet
Old Sep 17, 2004 | 10:27 PM
vsixtoy's Avatar
Car: '87 Cam RS V6
Engine: Top Secret
Transmission: DYT700R4 custom inerts and conv.
There are three different things I have done to this car in years past (and recent) that have show the most noticible improvement in engine performance and revving above 4000rpms.
1) was a highflow cat (A good quality one- watch what you buy, not all that claim "highflow" are equal) I run a Gibson SS unit (no longer availible. I will go to Random Tech SS next. The rear muffler and exhaust showed no improvement until I got rid of the stock cat.
2) was the install of a power pulley on the crank (ASP underdrive pulley)
3) was the Carbonfiber driveshaft- The car craves high rpm it revs so damn smoothly up to 5800 rpms and probably higher but I won't let it because there is no reason to toast the motor senselessly. Power stops at about 5200- I have rarely taken it past that. (edit: The driveshaft, just like most other things I have done so far, where put on there not to aid what I have now- but were put there first to handle what I intend to add afterwards. I built these things first so sh*t doesn't break when I add the power on a higher rpm range)
Old Sep 18, 2004 | 04:21 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The way GM made the cats in the 80's was restrictive; the way GM makes them now is pretty good- almost turns them into "high flow" from the factory!
But- a new GM cat is about $300. Aftermarket performance ones are about $100.
Anything will probably flow better than your aging stock cat. Once our catalytic convertors get old enough, the pellet bed breaks up and can clog the exhaust.
LT1Formula
Oct 8, 2015 08:34 PM
jaridjohn
Oct 5, 2015 07:01 AM
