Feiro valve covers
Car: 1987 Trans Am
I assume you tired to use the original ones, and they are too short? I'm pretty sure that we used the ones from the Fiero on Redraif's car...otherwise, you could probably take one of your too-short originals toa hardware store and match it up.
Car: check
Engine: check
Transmission: check
This gets a little trickier then grabbing some hardware store bolts. The Fiero valve covers use a special bolt with a shoulder on it. This prevents over-tightening and cracking the valve cover.
Try GM first. They may still carry them. Else some regular bolts with spacers will need to be used.
Post back if some dimensions are required.
RBob.
RBob.
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I was playing the hunt game at the junk yard. I think a few of the f-body studs were correct, but not all. So I kept robbing the right size. It been so long though I can't remember specifically.
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
