upper plenum
Old Oct 30, 2004 | 12:43 AM
kevo2k6's Avatar
Car: 1990 Camaro RS
Engine: 3.1L v6
Transmission: 700r4 auto
upper plenum
took off the upper plenum the other day to clean it because it looked gross. was black from dirt. ever since i took it off and put in back on the car seems to be runnin a lot richer and my gas mileage has gone down a bit. i also get a gas smell at random times. what could this be?
Old Oct 30, 2004 | 01:27 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
i'm guessing you knocked something outta place
Old Oct 30, 2004 | 02:22 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
did you clean off the gaskets really good? recheck egr connection, & the t-fitting in the back of the manifold.
might bean air leak.
Old Oct 30, 2004 | 06:19 AM
KED85's Avatar
Well we're not there
Your problems are not too common with what ya did.
What does sound like what happened is vacuum leaks
The Manifold is full of dirt due to routing of vacuum lines into the intake for emissions reasons.
IF your car ran sh!ttty before the end result is what ya now see. Carbon buildup.
Pull back off, check your work, lines, etc.
Take top and flip it over toward passenger side to avoid disrupting any lines/setting of TB & such.
IF ya already upset the lines & TB setting due to movement of upper intake, you have to start all over again.
Not there but yeah things can happen when ya disturb the sleeping bear!
Hoses patch by using 5/16" windshield washer line. Works perfect. I've spent whole day doing that and worth it.
Old Oct 30, 2004 | 06:55 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Did you knock off the vacuum line to the fuel pressure regulator?
sheachopper
Jul 31, 2019 11:27 AM
Ed1LE
Sep 30, 2018 09:14 AM
MrPackstin
Oct 25, 2017 08:09 PM
dbrochard
Interior Parts Wanted
Sep 28, 2015 07:40 PM
