computer
Old Nov 14, 2004 | 06:05 PM
chevytruck68's Avatar
Car: 86 camaro
Engine: 2.8
Transmission: 5 speed
computer
will the computer from an 88 camaro 2.8 auto work for my wifes 86 camaro 2.8 with 5 speed
thanks in advance
Old Nov 14, 2004 | 06:18 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Yep. Just swap the proms.
Old Nov 16, 2004 | 01:33 PM
Car: 86 camaro
Engine: 2.8
thanks Doward another question which one is the prom. i puled the 2 screws out removed the small cover on the one side of the computer and there are 2 removable chips. is it the small one or the big one or should i change both. oh and any special things i need to do to change the computer so i dont burn it up other than unplug the battery.
Old Nov 16, 2004 | 03:31 PM
Doward's Avatar
Should just be one - it's got a black plastic cover around it. It should be the 'bigger' one.
Old Nov 24, 2004 | 03:53 PM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I thought the computers had to have the same numbers to be a swap?!? Could be wrong.
As far as the 2 chips. Larger is prom. The other one is needed if you ever have to buy a new computer. Make sure you swap it in too. I only swapped the prom and oh boy! Car was not liking that! I think it ran, but was running horrible. There was no talking to check engine light...no workie
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
dusterbd
Sep 29, 2015 08:40 AM
Damon
Sep 26, 2015 04:29 PM
1nastygta
Sep 24, 2015 08:58 AM
