TPS voltage
Old Nov 17, 2004 | 08:33 AM
Buck89RS's Avatar
Car: 1989 RS
Engine: 2.8L MPFI Bored 30 over (Rebuilt DEC 2004)
Transmission: 5 - SPD With 3.42 open rear end
TPS voltage
I set the voltage on my TPS to 0.552 and WOT is 4.28, does this sound right to yall? Any advantages to higher voltage setting or lower for that matter. Thanks
-Buck
Old Nov 17, 2004 | 09:03 AM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
Sounds close... I believe it's more .54 @ idle, and 4.6 @ WOT
Perhaps your throttle body is not opening completely?
Old Nov 17, 2004 | 09:07 AM
Buck89RS's Avatar
Car: 1989 RS
It was open all the way, i just wasnt sure what was the normal for these things. Thanks
-Buck
Old Nov 17, 2004 | 10:35 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
I've got the same engine ('87 with an automatic), and my TPS shows 4.26 at WOT and 0.55 at idle. I was wondering if it shouldn't be higher at WOT. I'm pretty sure the throttle is open all the way.
Old Nov 17, 2004 | 02:27 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
Mine is 54 at idle and 4.58 at WOT. Hope that helps.
BumpaD82
Feb 26, 2016 02:57 PM
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
327IROC85
Sep 23, 2015 12:11 AM
