Building a 2.8 for mpg and reliability
Old Nov 22, 2004 | 12:34 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
alright guys, the way gas is i've decided against beefing up a v6, instead i want to build one to get the best mpg outta it possible.not saying i want a gutless wonder, but i figure i can build a v6 that has more power then my current one and get better gas milage. right now i drive roughly 800 km a week, and getting only 470 km (works out to 18mpg) to the tank i think i can do better.
where would all of you start.
this is building a 2.8 (3.4's are next to impossible to find and shipping one costs more then its worth)
i think a full port and polish of heads and intake is a good start, i'm mainly looking for cam suggestions.
Old Nov 22, 2004 | 12:41 AM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I'm only getting 300-350km per tank.
Old Nov 22, 2004 | 12:46 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
you doing mostly city driving?
90 percent of my driving is highway
Old Nov 22, 2004 | 01:01 AM
Yeah, I suppose that's an important factor. Most trips I take include some time on the freeway, but just short stints between 1st Ave and Gaglardi on the no. 1.
Old Nov 22, 2004 | 01:03 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
lol, yeah that burns a fair bit of gas, most of mine is driving between surrey and abbotsford
Old Nov 22, 2004 | 01:16 AM
Yeah, that'll do it.
As far as modifying an existing engine to get better mileage, I'm not too sure on that, especially as far as cams go. I'm sure stuff like proper lubrication of the drive train (good rear-end lubricant, good trans fluid, good engine oil), maybe reducing the rotating mass (lighter flywheel, lighter driveshaft, lighter pistons), and also reducing the weight of other pieces of the engine (rockers) might help. I'm not expert, but these are just a few ideas. Anyone feel free to jump in and agree or disagree with me.
Old Nov 22, 2004 | 02:07 AM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
what rpm do you cruise at? I know for a fact that these motors burn more fuel at lower rpm's than above 2500. Perhaps a gear change, and a big reduction in vehicle weight and engine rotational mass.
Old Nov 22, 2004 | 03:04 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
under drive pulleys, free flowing exhaust (i use to run a dynomax 2 1/2" catback, sounded pretty mean on the little 6 as well), k&n's, gut the air box. do away with smog equipment. put the car on a diet. at least 3.42's if not 3.73's. my car use to get 28-30mpg on the highway, and that was with the air on going through the mountains @80-85mph.
make sure your cruise control works too. as far as cam selection goes, i would look at what is available first, cause there isn't too much that is. maybe putting in a 3.4 stock cam.
Old Nov 22, 2004 | 03:30 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Your mileage sucks. I don't drive my V8 car but maybe a few months a years as all its gets is 18.
Id just get the motor nice and fresh. Switch to a stick. These cars come with 3:42 stock and you want to go lower for more mileage. Like a 3:08 2:73. high means faster and less mileage.
Old Nov 22, 2004 | 05:28 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
while you're building the engine up, incorporate the TomP* tune up as you go.
Old Nov 22, 2004 | 09:57 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
pullys
intake
exuast (including headers)
lighten driveshaft
ligthen break drums
a smoothing out of the upper intake
debur the heads (dont smooth them out, just make sure their are no burs)
full roller rockers, reduces friction, but quite expensive for the gains.
good clean proper injectors
finely tuned ecm
manual trans if your efficent at driving one
stay with the 3.42, or maybe swap to 3.23's or whatever the next step would be.
proper alighnment and suspension geometrics (front and rear)
lighten other parts on the car that would not cause safety factor.
keep the 195 t-stat
Old Nov 22, 2004 | 10:24 AM
He's got a stick already, so he's good to go there.
Old Nov 22, 2004 | 07:22 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
its stick, 3.42's out back and i cruise along at 2700 rpm
Old Nov 22, 2004 | 07:26 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
alright the plan so far
- full port and polish of the heads (flowmatched)
-pacesetter headers
-under drive pulleys
-aluminum driveshaft
-sending injectors to cruzin performance for cleaning and flow testing
-all new sensors
-all new accesories
as far as internals of the engine go any recomendations? i do need to keep this smog legal but i figure a freshly rebuilt 2.8 should already be giving me better mpg.
Old Nov 22, 2004 | 07:48 PM
Dale's Avatar
Engine: 350 S-TPI
Aluminum pistons I guess? but that is quite costly.
I'm not sure what a full port on the heads will do(mpg wise)? I just slightly deburred mine as it was eating up bits. It had alot of burs.
reliablity, you could always cryo the block n other parts, but thats about 600 for a full engine.
Old Nov 22, 2004 | 08:07 PM
Cryo?
Old Nov 22, 2004 | 08:32 PM
Slow2.8's Avatar
Synthetics all around, well the mpg won't be to noticeable, but the protection will definately suit your reliability needs.
Old Nov 22, 2004 | 08:38 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Originally posted by camaro_junkie
Cryo?
basically they deep freeze the block, makes it stronger
Old Nov 22, 2004 | 08:59 PM
I assume it's a heat treatment then? Probaby heated then quenched?
Old Nov 23, 2004 | 01:43 AM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
nope just frozen, i have a link to it i'll post it up and pm it to you
Old Nov 23, 2004 | 02:18 AM
Well I pm-ed you back, but just for the interest of anyone else, cryo is a continuation of traditional heat treatments that goes to very low temperatures to complete certain material property transformations.
edit: Oh yeah, and you can get cryo processing done for a decent price to all sorts of vehicle parts including brakes (lengthens the life) and of course, engine parts.
Old Nov 23, 2004 | 06:23 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
maybe someone can do some ecno prom tuning.
Old Jan 5, 2005 | 07:01 PM
kal's Avatar
kal
Car: 1983 Firebird
Engine: 2.8L-5.0 swap
Transmission: T-5 5 speed
You could try an MSD ignition box like the 6A. And a high voltage aftermarket coil like a MSD blaster or Accel. It will give better gas mileage and give a little bit more power. Also helps your car to start on those cold days. Just remeber to open up the gap on your spark pulgs or they will get too hot. The msd box will run about $100-140 and the coil is about $30-50
Old Jan 5, 2005 | 09:46 PM
Is there a consensus on opening the gap when you go to a higher voltage coil over stock?
Old Jan 6, 2005 | 01:28 AM
coolrimsatleast's Avatar
Car: 89 f-bird and some others
Engine: 3.4
My manual calls for .045, but I gap them at .049.
When I bought some plugs at autozone the guy offered to right down the gap on the boxes so I said sure. The computer told him .054 though. hmmm.
I installed all the msd stuff, underdrive crank pulley, dynomax muffler, homemade intake, synthetic oil, and check my tire pressure often. by the time the needle hits the 1/8 mark I've usually gone about 340 miles (around 28mpg). Pulled of 370-80 several months ago.
I need to get my CC working, fix my exhaust manifold leak, install roller rockers, and replace my squeeking alternator.
and get a 3.4.
I drive at a moderate pace, and also don't slow down around corners so I don't have to speed back up
Old Jan 6, 2005 | 02:48 AM
oil pan 4's Avatar
Car: 89 Firebird
So you just want good gas milage and reliability.
Look for lower tention street rings, get the wrist pins floated.
The stock pistons are cast Al, get some cast hypereutectic alloy pistons. There run you about 2X the cost of stock pistons.
Get a filter relocater, you can put in a cooler easy and a big honken oil filter will help you keep your oil pressure up.
The headeres are a good idea.
The high power ignition is a good idea, toss the stock coil.
Old Jan 6, 2005 | 04:00 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
ok guys i'm just trying to figure out which cam to use
either this one
http://www.cranecams.com/?show=brows...tType=camshaft
or this one
Old Jan 6, 2005 | 05:36 PM
oil pan 4's Avatar
Car: 89 Firebird
Get the bigger one.
Old Jan 6, 2005 | 06:05 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Could run an enrichment system of propane or hydrogen.
Both will drastically improve MPG but but, both explode nice during a crash.
Old Jan 6, 2005 | 09:33 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
alright, so i should stick with the 2030 as i thought
now heres the big question, are the 1.6 gold race rockers worth the $300 canadian? i've read that they give marginal gains, and for the price i could a few other goodies for the motor
Old Jan 6, 2005 | 10:30 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
Alright.. let me get this straight.. you're building for fuel economy, but you want a bigger cam... and people are telling you to use a bigger cam..
When did all sense of logic leap its way out of this thread?! What is the point of an MPG thread when you're doing gas guzzler mods?!?!?!
Old Jan 6, 2005 | 10:34 PM
TechSmurf's Avatar
Engine: LS1, Scrap
This is not about to help fuel economy either. Polished intake ports will reduce turbulence at the port, reucing fuel atomization prior to entering the combustion chamber. Any enlargement of the port will reduce efficiency at lower RPMs by reducing port velocity, also further reducing fuel economy.
Old Jan 6, 2005 | 10:56 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
i said i'm building this for better fuel economy(than i'm currently getting) i was looking for mods that would get me to 20- 22mpg tuned. With a custom burnt prom and finely tuned motor even with a bigger cam members on the board have gotten upwards of 26-28, while still adding a bit of pep to the 2.8
right now with my motor (200000km or 135k miles) i'm getting 18 mpg, i figure freshning up (with a rebuilt motor) and new parts should already get me to atleast 20 (hopefully more). i'm looking for something thats gonna give me a bit more power while still retaining reason i bought a v6(fuel economy).
i pretty much started this thread to find mods that would , in combination with performance parts, that would get me above 20 mpg so gas would be a bit cheaper
Old Jan 6, 2005 | 11:00 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
double post
Old Jan 7, 2005 | 06:45 AM
oil pan 4's Avatar
Car: 89 Firebird
My new LG4 was getting 25mpg-26mpg driving back home from texas.
Most of the atomization is done by intake being partly open on a small camed engine, the mixture does swirl, there is a quench aera on our heads.
Get after market injectors to help with atomization, that is one thing you have to do when you grind out the vane in the heads.
I say get even lower tention rings and run a vaccum pump.
Up the C/R if you can, you can run less timing and have more intake manifold vaccum. You will get real good scavanging with high c/r. A small cam will fight off detonation because it will keep the VE low, a stock 2.8's VE is just over 75% a hoped up 2.8 won't be much higher.
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
92firebirdguy
Sep 1, 2016 07:53 AM
Zane Story
Oct 8, 2015 12:40 PM
89bird2.8
Sep 18, 2015 07:46 PM
rjcme
Sep 5, 2015 01:23 PM
