What should the vacuum be?
Old Dec 11, 2004 | 08:07 PM
Damien00677's Avatar
Car: 2006 'Nox 91 Camaro RS 91 1500 Silv
Engine: GM 3.8L, 305 SBC, 350 SBC
Transmission: Auto, auto, auto
How much vacuum should I have at idle? I think I pulled 14psi last time I checked. Would an aftermarket cam affect that?
If its low, I just can't seem to find the leak. I spent some time today following all the vacuum lines that I know of with the propane tourch listening for increased idle, but found nothing. Is there a better test for this?
Old Dec 11, 2004 | 09:11 PM
FbodTrek's Avatar
Car: 86 Berlinetta 84 MonteCL
Engine: 3.4 MPFI 3.8 229
Transmission: 700r4 T350
Re: What should the vacuum be?
Not sure what it should be stock. I'm pulling 17 In/mg myself, and I have a Cam. I would guess that you either have timing issues, or a bad vaccumn leak. If it's not those things, It's mechanical 9burnt valves, rockers too tight etc.). I'm not sure if it's within specs, but it sure sounds low.
Old Dec 11, 2004 | 11:47 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
I have a very mild cam pulling 19"
Stock is right around 20"
Both @ 1000rpm
The bigger the cam, the less vacuum you will have.
Old Dec 12, 2004 | 03:03 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I thought mine was around 18 @1000 on stock cam?? I may be wrong.
Old Dec 12, 2004 | 03:48 PM
When I checked mine, it was at 750 rpm, i should try it at 1000 to get a better comparison
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
HoosierinWA
Oct 7, 2015 10:15 AM
timonator
Sep 30, 2015 12:52 PM
dusterbd
Sep 29, 2015 08:40 AM
